GPS connection for field navigation
1179
12-23-2011 04:39 AM
JonathanHodel
Has anyone had success in using ArcGIS Explorer with a Garmin or other type of GPS connection to navigate in the field.  I am working with some public utilities to give them a viewing application in the field on their laptops or tablets.
EdanCain
Johnathan,
when you say you can't get it working in the field, I am presuming that you have it working in your office. Is that correct?
If no is the reply, Garmin devices when connected to a computer typically don't show up as a port without the use of Garmin's Spanner application. All Spanner does is create a virtual COM port, and through this the Explorer GPS code can connect to the port, receive the gps sentences and display your position.
Let me know how you get on.
Edan
