Features disappear on zoom?
22303
31
04-14-2010 07:12 AM
Public_HealthObservatory
I have an AGX 1200 project with a series of boundary shapefiles in it. At the full extent of the shapefiles (all shapefiles have the same extent), I can see all the features of all of the shapefiles. However, when I zoom in, some of them disappear. Some shapefiles work at any zoom level, and some of them disappear when I zoom in. First just part of the features will disappear, like the right half of the extent. Then as I go in further, they disappear completely. None of them have any minimum/maximum display scales set. The ones that work, work consistently, and the ones that fail, fail consistently.
Can anyone help? Thanks in advance!
PeterLindstrom
Oddly enough, I only have the problem in 2D. I'd rather clear the cache every time than use 3D when I don't need it, though (because of performance issues).
KristinWinchell
I found a solution to this here: http://resources.arcgis.com/content/kbase?fa=articleShow&d=24610
Deleting the corresponding .sbx and .sbn files seems to fix the issue.  I'm guessing that if the issue reappears then re-deleting these files will fix it again...
PeterLindstrom
I'm using file geodatabases, so the shapefile fix won't work for me.
MichaelBranscomb
Esri Frequent Contributor
Peter,
If you can post your data on the forum I'll happily test it here.
Regards
Mike
ShellyBianchi-Williamson
Although time has passed from the last posting, I wished to provide insight. Under C:\Documents and Settings\[username]\Local Settings\Temp, the A3 folder contains the caches that need to be purged on a regular basis, especially if the same default map or AGE project is opened time and again. By not clearing the cache, the feature class/layer symbology [not labeling] will disappear.
As a resolve to the matter, I use a .vbs script that purges all of the C:\Temp folder when a user logs in and for those, that rarely logout during the day, a desktop shortcut to purge as needed during the day. I have also upgraded from AGE 1200 to the latest version 1500.
PeterLindstrom
sbianchiwilliamson's method seems like a decent work-around, but I'd still like to see this resolved in a way that doesn't require any user intervention.
I've been testing the main layer that's been giving me problems (ownership), and here are a couple of observations:
  • Exporting from my central file geodatabase to a layer package seems to resolve the problem, at least mostly. I still get an occasional "hole" when it uses cached data. And I'd rather have ArcGIS Explorer users connect directly to corporate data rather than derived layer packages.
  • The effect seems to be worse when the data is added to maps with a lot of layers on them.
I would upload some data for others to look at, but I can't seem to get the file to attach to my message - I get this error message: "Bad Gateway - the proxy server received an invalid response from an upstream server."
MichaelBranscomb
Peter,
As far as I'm aware we have not yet been able to reproduce this issue. If you are not able to upload data to the forum please feel free to email me at [email protected].
Regards
Mike
NicholasGross
I have the exact same problem. Features disappearing as I pan or zoom in on the map or sometimes only labels showing up. Deleting the entire cache, or just the cache for that layer solves the problem, but only temporarily. The next time or two that I use the same map, the same problem begins again. It's a hassle when several layers aren't functioning properly, making a full cache delete and restart the only practical option.
This problem is common on at least three machines (all of different makes and models) that I'm aware of. I'm using layer files referencing file geodatabase feature classes. The gdb is version 10 and Explorer is Build 1500.
RickHollatz
I've also had the exact same problem but seem to have found a means to work around it.  I'm using Explorer build 1500. In my current case the failing layers are layer packages (.lpk) built in ArcGIS 10.  I've also watched it happen last week in shapefiles and FGDB feature classes.  Only two out of several layer packages are experiencing this issue in my current Explorer project.  They work fine for a while panning and zooming, but it seems that once the cache for these particular layers gets to a certain size of around 2mb they start to fail in the map (I've been watching the file sizes in the default cache directory C:\Documents and Settings\...username...\Local Settings\Temp\E3).
My work around is to change the 'Refresh Options' for the particular problem layers.  Go to Layer Properties, Source Data, and choose the radio button for "At a specific time interval".  It doesn't seem to matter what time interval you set. I tried "1 hour" and also "1 minute" and both worked immediately to solve the problem.  You need to save the your project for the setting to take effect permanently.
As a side note...It seems like the refresh option for "When the map is opened or the layer is added" would similarly solve the problem but it does not.  That option apparently has a bug.  See this forum http://forums.arcgis.com/threads/15362-Help-me-understand-caches-and-refresh-options?highlight=explo...
-Rick
