Explorer 1200
3974
16
03-09-2010 08:07 AM
BartHound
Will this get changed at some point, to something a bit more standard, naming is getting a bit long now at 4 characters (1200), I would hate to see Explorer 1,000,000.
BartHound
Any word for an update for this release, I imagine there will be something prior to Dev Summit?
FranciscoManjarrez
Ted,
The new ArcGIS Explorer (Build 1200) is now available for download:
http://blogs.esri.com/Info/blogs/arcgisexplorerblog/Default.aspx
Frank M.
BartHound
Thanks Man, looking forward to this, is this a public offering, and if so, can I just post to these forums.
If you can pat Edan on the back for me.
BartHound
Are there any plans to release the silverlight app as well, or is this just a prototype at this juncture?
FranciscoManjarrez
Ted,
At this time there is no specific version number for ArcGIS Explorer (unlike other ESRI Products) other than the newest public release being identified by the build number, hence ArcGIS Explorer 1200.
Having said that, the new ArcGIS Explorer is optimized for ArcGIS 10 yet will still work with previous versions of ArcGIS. I hope this information helps resolve some initial confusion.
Frank M.
JoshWhite
Honored Contributor
Ted,
Frank M.
I still agree with Bart on this one.  That is one heck of a number.  Couldn't it at least follow the pattern of ArcGIS products?  Or perhaps Even be called 12 instead of 1200?
Josh White, AICP
Principal Planner
City of Arkansas City
TedCronin
So, this is the actual release.  This is NOT a beta of ArcGIS Explorer, correct.
FranciscoManjarrez
Ted,
That is correct.
Frank M.
TedCronin
Thank you Frank.
