Explorer 1200 crashes when attempting to add content from file geodatabase
732
08-02-2010 08:44 AM
AmyBrassieur
Every time I try to add data to Explorer 1200 from a file geodatabase, it crashes. I thought it was because I just upgraded to ArcGIS Desktop 10, but it's happening on older geodatabases too.
I need Explorer for a project in the interval before I get a server, and this kills it.
Is it something to do with my new ArcGIS Desktop 10 install?
MichaelBranscomb
Esri Frequent Contributor
Amy,
If you have used ArcGIS 10 with those File Geodatabases and upgraded the schema to the 10.0 schema then ArcGIS Explorer 1200 will not be able to read them - the imminent 1500 release will resolve this. However, if the schema remains unchanged from when you used them in 9.3.1 then my suggestion would be to try reinstalling ArcGIS Explorer 1200.
Regards
Mike
