Error 1316 When Installing ArcGIS Explorer
2519
06-09-2011 02:11 PM
JohnMcClure
I have repeatedly attempted to install build 1500 and always receive the failure message: "Error 1316. A network error occurred while attempting to read from the file c:/docume~1/john/locals~1/arcgis~1/1500/setup/8c8a18.msi".
I have downloaded the file from ESRI both by using run and save and receive the same results when I attempt to install.
As you can see from the attachment my computer meets the requirements to run this program.
What do I need to do to be able to install this program??
ALEXRoads
Error 1316 is an irritating installation error. It pops up when a software is being installed, uninstalled or repaired on your computer. You may get the following description while seeing this error: Error 1316: "A network error occurred while attempting to read from the file: :\Install.msi" Are you wondered what causes this glitch? No need to worry. This article is all about the simple and user friendly steps that help you fix error 1316 Windows 7.
    1. Use Windows Installer Clean Up
    2. Use a Registry Fixing Utility
    3. Change Windows Installer Registry Information
    4. Check the Security Details of the Concerning File
I also faced this error many times but i fixed it, i also got some help from this website error 1316 , hope someone might get help from this website.
