Dragging Layers From One Map to Another
829
04-14-2011 02:41 PM
JustinSmith
I ran into an issue today I have never seen and I was hoping that someone would be able to help me out.  I have two maps, both at a scale of 1:60,000 and both at a 24x30 document size.  I dragged road layers from one map into the other.  However, the map in which I dragged them into appears quite different.  The text is much smaller than it is on the other map with regards to the road labels and the thickness of the actual road layer is much smaller as well.  Both layers however are the same size in the properties.  Also, both layers labeling properties are the same.  Why would they be different in appearance???
Justin
KirstenSeverud
Did you check to see if there is a different reference scale set for the two different data frames in your different maps?
