Display Expresion in ArcGIS Explorer
1238
10-09-2013 12:37 AM
MichalMichalski1
I have a ArcGIS Layer (point) created in ArcMap with display expression NAME. However when I open the same layer in ArcGIS Explorer the display expresion is not preserved and a random attribute is chosen once I double-click on feature.
Is it something what ArcGIS Explorer does not reckognize?
Thanks
Michal
PaulLohr
The attribute column is called "NAME"? If that's the case, try displaying a different attribute column (if you have another). You can try copying the values to a new column - maybe call it "NAME_" or "NAME2".
Paul Lohr
Lohr Geospatial Services, Inc.
