display a new layer using ArcGIS Explorer SDK
932
08-14-2012 02:12 AM
Gyeong_MinRoh
Hello.
I'm trying to make an ArcGIS Explorer Add-In for internal use.
What's I wnat to do is to display a shapefile in current display when a user click a button.
I already tried the sample code from SDK help but nothing happens.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using ESRI.ArcGISExplorer;
using ESRI.ArcGISExplorer.Application;
using ESRI.ArcGISExplorer.Mapping;
using ESRI.ArcGISExplorer.Geometry;
using ESRI.ArcGISExplorer.Data;
using ESRI.ArcGISExplorer.Threading;
namespace anakPetak
    public class anakPetakButton : ESRI.ArcGISExplorer.Application.Button
        public override void OnClick()
            //Create a DataSourceProperties object that holds the connection information to the feature class.
            DataSourceProperties featureLayerConnectionProps = new DataSourceProperties(@"C:\Korintiga\npa_tanam.shp");
            //Create a feature layer.
            FeatureLayer anakPetakFeatureLayer = new FeatureLayer(featureLayerConnectionProps);
            //Connect the layer to the feature class.
            bool connected = anakPetakFeatureLayer.Connect();
            //Add the layer to the map.
            if (connected)
                ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay.Map.ChildItems.Add(anakPetakFeatureLayer);
                System.Diagnostics.Debug.Print("Test");
            else
                //Investigate connection issue.
                ConnectionStatus status = anakPetakFeatureLayer.ConnectionStatus;
                if (status.HasError)
                    System.Diagnostics.Debug.Print(status.ErrorString);
Would you please give an idea?
Many thanks.
Gyeong_MinRoh
I already tested with file geodatabase format and it worked...
Doesn't the DataSourceProperties work with shapefile format?
Tks.
