Custom Popup with AE API
2442
02-17-2011 08:45 AM
MargoBlosser
I am working on a custom popup that I want to have act in a very similar manner to existing AE popup.  I need the popup to access data that have a one-to-many relationship.
The approach I am taking is to create an extension add-in, but the problem I am having is how to get the popup to fire, what event can I use to trigger the extension to run its code.  I have seen examples that use the GraphicClicked event, but what I need is an event for clicking on the activemapdisplay. I want the custom popup to fire much like what the out-of-the-box AE popup does, with a mouse click.
Can someone point me in the right direction?
Best Regards,
Margo
AndreiIvanov
Margo,
MapDisplay class listens to GrahicClicked and MapItemClicked events. AGX API does not expose MouseClicked event for mapdisplay.
srinivasreddy
If u want to add popup at mouse click on the map, Mouse click is not there but u can use TrackDelegate, Here in TrackInfo u r having the poinadded property.
i,e when ever u click on the map one point will add here it will also give geometry.......
