Change Navigator Position
1544
07-01-2016 07:08 AM
MichelleD
I want to change the Navigator Position to top left in AGX.  I changed the position on the Display tab or in Options>Map Window, but every time I close and reopen a map, it reverts back to bottom left.  I tried tweaking the NavigatorPosition setting in settings1500.xml, but it didn't help (upon open it was in the bottom left until I clicked on the Display tab, then it moved to top left).
Is this a bug, or is AGX supposed to revert back to bottom left?  Is there a way around this?
