Can I change coloring of shapefile features based on values in ARCGIS Explorer Desktop?
4190
08-22-2014 06:59 AM
ArickMorton
I have a shape file that has median household income for all census block groups in Texas.  Can I change the color of the block group based on the household income value in ArcGIS Explorer Desktop?  Thank you for your help!
JakeSkinner
Esri Esteemed Contributor
Hi Arick,
Yes, take a look at either applying a unique value or graduated color symbology to your shapefile.
JakeSkinner
Hi Arick,
ArickMorton
Jake,
Thank you very much for your response!  Just to clarify - I am trying to do this in ArcGIS Desktop Explorer as opposed to just ArcMaps.  Is that possible?
Arick
JoeFlannery
Honored Contributor
Arick:
Yes you can set the color and use it in AGX.
In ArcMap, Symbolize your shapefile by Category using an attribute field then right-click on the shapefile layer in the TOC and choose Save As Layer File.  Now add that LYR file to your AGX map and you're good to go!
