I have a shape file that has median household income for all census block groups in Texas. Can I change the color of the block group based on the household income value in ArcGIS Explorer Desktop? Thank you for your help!
Hi Arick,
Yes, take a look at either applying a unique value or graduated color symbology to your shapefile.
Arick:
Yes you can set the color and use it in AGX.
In ArcMap, Symbolize your shapefile by Category using an attribute field then right-click on the shapefile layer in the TOC and choose Save As Layer File. Now add that LYR file to your AGX map and you're good to go!
Jake,
Thank you very much for your response! Just to clarify - I am trying to do this in ArcGIS Desktop Explorer as opposed to just ArcMaps. Is that possible?
Arick
