Can AGX create shapfile from Note ?
1174
06-21-2010 02:36 PM
Yi-ChenYang
Dear all,
  If I have a folder of notes that I create from a procedure, can I create a single shapefile from the folder that contain all the notes in ArcGIS Explorer?
  Thanks a lot in advance.
Ethan
ShellyGill2
Hi Ethan,
ArcGIS Explorer cannot create or edit shapefiles I'm afraid, and this will not change in the forthcoming new release.
If you have ArcGIS Desktop available, that would be the best way to create a shapefile. Using the Explorer SDK it would be fairly simple to write an add-in that exports a folder of Point notes to a CSV text file, which could be imported into ArcMap as an X, Y layer - at that point you could use ArcGIS Desktop to perform the conversion to shapefile. I imagine there are also geoprocessing tools to do something similar (although I'm not very familiar with the range of tools available).
Yi-ChenYang
Dear Shelly,
  Thanks for the quick reply!
Ethan
