[ArcgisExplorer]Problems and questions functionalities
1692
04-16-2010 03:57 AM
sigsig
I use Arcview 9.3, and in order to share projects and symbolgy with some users, I installed Arcgis Explorer. But I meet some difficulties:
1. Does it exist the possibilty to of parameterizing the zoom?
2. When you import un layer package, you can't see attribute by pointing the mouse over the object. Do I have to add .shp to see informations?
3. Is there a way to print the legend with the map?
4. How can I add .ECW files?
5. How can I add the north arrow?
6. I can't connect to GIS Server? The application says: "Autentification failed".
7. I find the print result is very bad, even if I choose 600 dpi for vector's layers. Is it normal?
Thanks a lot
FabioPetaccia
hi,
by my experience I can answer this question:
1. No you can not do anything to zoom
2. When you create a package you must be sure that all shp and .lpk have "HTML Popup" activate
4. No (I have a lot of ECW file, but I must create a service to load on AGX)
6. I never do problem with GIS Server, version 9.2, 9.3 and 9.3.1 works without problem
Hop to help you
If I write something else please correct me 🙂
Fabio
sigsig
Hi Fabio,
2. Where do I choose "HTML pop-up"?
4. So I need to convert ECW in another format? What is AGX?
MarkSquires
Hi Fabio,
Regarding the formats that ArcGIS Explorer (AGX) supports, the link below should help:
http://webhelp.esri.com/arcgisexplorer/1200/en/add_raster_data.htm
Also, HTML pop-up must be enabled when you create the layer package in ArcMap. The following link below explains the HTML pop-up option:
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=226&pid=212&topicname=Setting_HTML_pop-up_pro...
FabioPetaccia
yep! that's all!
thx Mark
