ArcGIS Explorer SDK - Display Feature Popup
862
09-27-2011 10:31 AM
SeanConnolly
Hello,
The ActiveMapDisplay.ZoomTo function works great.
I would also like to display the Popup window associated with the feature I am zooming to. Is this possible using the SDK?
Here is my code for the ZoomTo function:
Dim r As Row = tbl.Search(New Filter("ID = " + intID.ToString)).GetFirst()
map.ZoomTo(r.Geometry, 1500)
AndreiIvanov
Sean, not directly from the Row class. You might consider creating Popup class associated with the zoomed feature.
