ArcGIS Explorer Presentation Effects
807
04-22-2010 06:14 AM
NickJacob
I came across a couple of comments from an ArcGIS Explorer Blog posting about presentation effects and I was wondering if anyone out there had any similar ideas.  Specifically I'm looking for ways to improve the transition between slides in presentation mode.  A "fade" effect sounds pretty cool as well.
Comments
# re: New releases of ArcGIS Explorer and ArcGIS Explorer Online at FedUC
I use ArcGIS Explorer primarily for the presentation functionality, which is great. My biggest problem with it, though, is the inability to adjust how data transitions between slides. If slide 1 shows dataset A and slide 2 shows dataset B, dataset A remains shown while the camera flies from slide 1 to slide 2, and then dataset B suddenly snaps in. It would be nice to be able to control what is visible while flying, or even allow datasets to "fade" in and out. Is this kind of improvement on the radar? Is it something that could be an written into an add-in?
Tuesday, February 23, 2010 1:47 PM by ryan.clark
Thanks for the comments and feedback. We've had requests similar to yours, and adding some slide transition capabilities is something we expect to do in a future release. Controlling the "snap in" of data is something you can do already using some slide capture techniques. The same is true for the fade in/out effects. I'll cover these in an upcoming blog post.
Friday, March 05, 2010 8:58 AM by ArcGIS-Explorer-Team
Nick
Washington, D.C.
