ArcGIS Explorer 900 and WMS
1907
6
05-28-2010 08:06 AM
clarkwoodward
I have a WMS loaded into ArcGIS Explorer 900. Each polygon renders correctly. However I am unable to click on a feature and return a popup of attribute information. Does ArcExplorer support popups on WMS layers?
ArcGIS Explorer 900
Windows 7
also installed is ArcGIS 9.2
Thanks in advance.
Clark
ThomasMathew
With ArcGIS Explorer 900, you cannot identify attribute information from WMS layers. This is logged as a software limitation with the following tracking ID and synopsis.
NIM048929 - Pop up Content in ArcGIS Explorer does not work for WMS Service layers.
clarkwoodward
Thanks Thomas!
Are you aware if this issue was corrected in 1200?
Will it function in 1500?
Thanks
Clark
AndreiIvanov
It works in 1200 in 2D view only. 1500 will stay same way.
JoeFlannery
Honored Contributor
This limitation persists in AGX 1500.
AndreiIvanov
Joe, can you provide WMS for a test?
JoeFlannery
Honored Contributor
Andriy:
We upgraded our ArcGIS Server to v10 and now attributes are returned to the end-user from our WMS map services.
