ArcGIS Explorer 1750 Doesn't start
1226
01-14-2013 03:54 AM
StavMap
I had a computer with arcgis explorer 900 installed. I uninstalled the program and installed arcgis explorer 1750, the installation was successful. When I try to open the program, i see that opening screen for a few seconds and then it disappears as does the process from the task manager. If i try to open the configuration manager, it does open.
What could be the problem?
Stav
yugrakhash
I'm suffering from the exact same problem.
1750 used to work fine. Then I tried and failed to install the 2012 beta version.
After removing the beta, 1750 started crashing when started.
Any ideas?
LeeBarnwell
Have you tried updating the video driver in the computer/laptop?  We have found if 1750 crashes immediately on startup or crashes when the map is zoomed or panned, that updating the video driver usually fixes the problem.
