ArcGIS Explorer 1500 crashes with Create Tools
804
09-07-2011 05:38 AM
CathyCole
I know about labeling notes and that the labeling option cannot be chosen unless a point is created.  I think I need to clarify what I mean by ???labeling???, because I was using it in a broader context.  If I try to add any of the shapes under ???create???  (point, line, circle, arrow, etc.) the program shuts down.  For example, I had a project that the Section A part  is active, but Section B part has been completed.  When I tried to draw a line to highlight (label) the Section A part , the program shutdown.  When I tried to draw arrows to show the limits of the project, the program shutdown.  When I tried to add a point then label the point with a  note, the program shutdown.  I can change the base map, add additional NC Map Services, zoom in and out with no problems.  Anytime I try to add something  via the ???create??? tool bar the program shuts down.  In talking to others that have had problems, they experienced a similar issue.
