ArcExplorer Hangs/Crashes When a Layer with Labels is Added
3117
07-15-2013 12:37 PM
AdamGuo
I can't figure out why my ArcExplorer won't map anything and hangs when I add ANY layers created by ArcMap with 'Label Features' turned on. The layer will work fine with 'Label Features' is turned off, so it is not a data problem. I am using ArcExplorer 2500.
I know I can convert my labels into annotation but I spoken with the ESRI tech @ the UC conference last week saying that there shouldn't be any issue with dynamic labeling.
Any one with ideas on how I can trouble shoot this?
I am working with a work station and I pass the system check from the ESRI website.
Thank you.
MarkBockenhauer
Does the problem occur if you open this layer package?
http://www.arcgis.com/home/item.html?id=7efee83a32b044fb8b213d92ae3a4d9a
It is a point layer with Arial font labels and simple halo.
Mark
AdamGuo
Hi Mark,
Yes it still does unfortunately. It will zoom to the area of the points and just hang and become unresponsive. And I will need to go into Task Manager to shut down the program manually.
AdamGuo
BUMP..
Anyone else have this issue?
It has been stated before with previous version that it was graphics driver problem. I have the NVIDIA Quadro 6000 with the most up to date driver....
Any ideas?
