Add-in cache directory
3578
10-15-2010 12:03 PM
DarinKwasniewski
Utilizing C# is it possible to access the cache directory from code. i.e. I wish to deploy a data file with the eaz and be able to retrieve it during runtime, therefore I need to get the path. (I would prefer not to build the data file as a resource).
MichaelBranscomb
Esri Frequent Contributor
There was a blog post on bundling files with Add-ins - which uses the 'Content' build action: http://blogs.esri.com/Info/blogs/arcgisexplorerblog/archive/2009/09/17/tip-for-add-in-developers-how....
However, the cache folder is within the Add-ins folder under the user profile - e.g. C:\Users\mbranscomb\AppData\Roaming\ESRI\arcgis explorer\Addins\Cache. Therefore you can get to this location in .NET:
e.g.
The following code:
string path = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData);
Returns:
"C:\\Users\\mbranscomb\\AppData\\Roaming"
Regards
Mike
