@AzinSharaf I was able to reproduce your issue. I noticed if the filter doesn't return any results the Feature Info will display no data, which is correct. However, once I modified the filter the Feature Info did not update unless I toggled off and on the filter to run the filter again. The expected behavior is the Feature Info should update with the new results. Thanks for letting us know about this. We will get this fixed soon.
David
