Zoom to selection URL parameter does not work
1106
04-23-2025 06:56 AM
Sfortunatamente
I have a url which selects the feature. I can see that selection on the map but adding "zoom_to_selection=true" does not zoom but pans the map.
here an example:
experience/?id=9077fb48ea4f4e13b9892859e384c753#data_s=id%3AdataSource_5-194cb6decdc-layer-1-57%3A323&zoom_to_selection=true
What am I doing wrong?
DanielFox1
Hi @Sfortunatamente
This is currently an enhancement request which is under consideration (ENH-000174440)
I would recommend raising a support case with your distributor and have the enhancement attached if it matches your scenario (judging by the above I think it does), then you will be able to follow the updates on the enhancement.
Ke_Xu
by Esri Regular Contributor
Hi @Sfortunatamente,
After selecting the records, please refresh the URL, it will zoom to the selected records.
Ke
