Working with Joined Feature Views in Experience Builder - Can they trigger another editable layer with identical GUIDs?
978
12-16-2024 01:24 PM
KevinBrock_FBL
Hey Folks,
I have a Hosted Feature Layer produced by Survey123 Connect for maintenance requests - It contains the Survey Layer (Survey), a Parent Layer (Windows), and a Child Layer (Child). I am using Experience Builder to help the Field Workers visualize and edit data.
Windows contains maintenance windows for each survey submitted, I used the GUID to ParentGUID to create a joined feature layer view (WindowSurveyJoin) to populate tables in Experience Builder, since, in order to properly ID a maintenance window, info from both the Survey and Windows layers is needed.
I am aware that Joined Feature Layer views cannot be edited, so I wanted to know if there was a way to trigger the edit widget to populate the original Windows layer, when selecting records in the table that are based off WindowSurveyJoin.
Right now, I currently have a trigger added to the Map widget that Select Data Records with Action Settings as follows:
Trigger Data: WindowSurveyJoin
Action Data: Windows
Conditions:
ParentGlobalID
to
ParentGlobalID
This trigger doesn't seem to change anything in the app when testing it in live view. Any suggestions would be appreciated, and I can provide screen shots and additional clarifications if necessary.
Ke_Xu
by Esri Regular Contributor
Hi @KevinBrock_FBL,
How do you create a joined feature layer view?
Ke
