Working with different resolutions in Experience Builder
3253
06-23-2023 05:20 AM
GeoprocessamentoNovaLima
Hello everybody. I have a question related to Experience Builder. I'm developing an application, and when I change the resolution. for example: 1280 x 1024 to 1920 x 1080 the screen is misconfigured and I can't create an application that is compatible with different resolutions. Could someone help me to resolve this issue? Thank you for your attention and good work.
jcarlson
In the style tab of a widget's configuration, you can set the size and the spacing to be a fixed pixel value. I'm guessing yours is set to be a percentage?
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
Thanks Josh for the information. I didn't know it was possible to fix the spacing. I tested it and the problem was solved. Thank you very much for your attention.
