widgets access feature layers from external sources
771
01-05-2023 05:42 PM
LefterisKoumis
It seems that most of the ExB widgets cannot be configured to display data from added feature layers (fLs)  by using their REST url or from feature layers generated from a query. An example is the table widget.  The web AppBuilder's  attribute table was able to create a tab for every fL that was on the map. Another example is the Query widget. The emphasis in ExB is using layers that are on the webmap.
Other that developing custom widgets, I don't see these WAB types of widgets to be introduced on ExB.
@RobertScheitlin__GISP  any comment?
TonghuiMing
I am not quite sure I understand you correctly, but you can add the feature layer service URL directly in the add data panel:
If you were to use a feature layer generated by Query or other widgets that can generate output datasources, just choose the output ds for the desired widget:
