The "Feature Info" widget have some bugs when interacting with an imagery layer coming from a webmap.
1. It does not display the Service Pixel values despite it showing properly in the context window of the map:
2. If I disable context windows for the webmap in Experience builder, I can still see the context window information in the "Feature Info" widget (Good!), but I can no longer see the context window information of imagery layers.
Please help.
Hi, @Nicolas_
I’d like to confirm some details about issue 2. Do you mean that after disabling “Enable pop-up” in the Map widget in ExB, without taking any further action, the attribute information is still visible in the Feature Info widget? And after clicking the map again, no feature can be selected and no attributes are displayed in the Feature Info widget?
Thanks!
1- I disable “Enable pop-up” in the Map widget in ExB
2- I then click on a point feature
3 - Feature information appear in the Feature Info widget (but no popup appear on the map as expected). This is a good behavior to me. I would simply like the Imagery layer information to also show up in the Feature Info widget if "Enable pop-up" is disabled.
Another error with the widget: the arcade "$userinput" variable seems to have different coordinates between the map pop-up and the Feature info widget informations:
