When using Utility Network Trace widget, why do I need to input a start point while trace type is subnetwork?
1180
05-08-2024 02:33 AM
IDT_tinghuahuang
I am using exprience builder ver1.14
When I using Utility Network Trace widget, I choose the trace configuration which is a subnetwork trace.
Subnetwork trace should not need a start point (in fact, you can't have a start point in REST API when doing a subnetwork trace).
But the widget still ask for a start point, am I doing anything wrong?
AlixVezina
Hi @IDT_tinghuahuang , yes that's a known limitation right now.
AlixVezina
