When running behind proxy at subdirectory, calls to some urls are still to root
2092
6
06-09-2024 04:47 PM
JoshGore
Trying to run Experience Builder behind a proxy at a suburl - I'm finding some of the calls are still to root, eg.
/signininfo
/sharing/rest
/apps/
GertConradie
Hi Josh
Are you using Experience Builder Developer edition? - if yes, how did you configure the app to use a proxy?
JoshGore
Yes we are using Development Edition. We are starting the server using the npm start -- --path option (e.g. npm start --path /our/path) as in the docs. This works for most requests, but not the ones listed above.
RClavero
Hello, we are encountering the same issue. And indeed, this is indicated in the docs (see Point 9).
I contacted Esri Support, so if do get newer feedback, I will share it.
Do you have any recent news maybe @JoshGore? Many thanks in advance.
ShengdiZhang
Hi @RClavero @JoshGore
We plan to fix this bug in the next release.
Regards,
Shengdi
RClavero
Thank you for the update, @ShengdiZhang. Best regards,
JoshuaGore
Great news, thanks!
