Version deletion issue
573
03-02-2026 01:18 PM
HusamOqer95
Hello,
We are working on an Experience builder application we are using the branch versioning widget to allow users to create their own versions.
I noticed that the delete option in the tool stopped working for some reason, so neither the version owner or the admin can delete any version from the Experience builder app.
I also noticed that the owner can only delete it from within ArcGIS Pro using the delete version tool.
I am super sure that this option was available before (with a different SQL database) but I am not sure what happened now (the person who was responsible for creating the database mentioned that he gave us all permissions to create and edit/delete).
The old SQL DB isn't available anymore unfortunately to compare it with the new one.
Any one faced this issue before?
Thanks!
StephanieW
Hi @HusamOqer95 when did you start seeing this behavior? Also are you using Experience Builder in ArcGIS Online or Portal for ArcGIS? A Support case would be ideal to look at this a little closer https://support.esri.com/en-us/contact. Thanks!
HusamOqer95
Thanks for you reply Stephanie, I started seeing this behavior 2 weeks ago using the  Experience Builder in Portal.
I have submitted a ticket for Esri support hopefully they can assist in resolving the issue.
