using the search option in experience builder
970
04-01-2021 12:59 PM
LarisaJohnstone
Hello,
Can anyone help me configure the search option on a hosted feature layer that I am using in an Experience that I am building? The current search I am using will only return results if they are exact. Is there any way to make this return all results that contain the word I am searching?
Thanks
Larisa
DavidMartinez
In the application settings for your webmap under the find locations > layer you can use the contains option. I am assuming you're using the search tool in the map widget.
Cheers,
David
