Use locally hosted jsapi instead of CDN
1818
03-18-2022 02:16 AM
Ranga_Tolapi
How to make ArcGIS Experience Builder Developer Edition v1.7 to use locally hosted JSAPI v4.22 instead of CDN?
Tags (4)
SumitZarkarCT
@Ranga_Tolapi
There are four places you will need to update the variable arcgisJsApiUrl with your local JSAPI host URL. For example, replace var arcgisJsApiUrl = 'https://js.arcgis.com/4.22/' with var arcgisJsApiUrl = 'https://exb.esri.com/4.22/' in each of the files below:
  • <install folder>/client/dist/index.html
  • <install folder>/client/dist/experience/index.html
  • <install folder>/client/dist/template/index.html
  • <install folder>/client/dist/builder/index.html
Refrence - https://developers.arcgis.com/experience-builder/guide/install-guide/#offline-install
SumitZarkarCT
@Ranga_Tolapi
