usage of react components outside of a widget
575
07-02-2025 12:42 AM
WalaZargouni
Hello everyone, is it possible de define a widget that renders partially ?
For example: i want to define custom react components outside of a widget (like in shared-code) and consume these components in the concerned widget without it really being there.
to be concise, i want to render a react component directly on the map for example without it being wrapped in a widget component, is it possible ?
I'm on ExB 1.17
JeffreyThompson2
MVP Frequent Contributor
I'm not sure what you are really trying to ask, but I will try to answer your questions as they are.
It's not possible to make a Widget that partially renders. React will crash if it does not return valid JSX at any point in time.
Can you define a React Component with in the shared-code folder? I have not tried it, but it should work. It's the primary reason the shared-code folder exists.
Anything rendered in Experience Builder will be part of the Widget class. If you want to place your Custom Widget on top of a Map Widget, that is perfectly valid.
GIS Developer
City of Arlington, Texas
