URL Parameters
405
05-12-2026 12:05 PM
vijaybadugu
I would like to know is there any possibility to disable the button in the list widget based on the URL parameter . it is quite possible with customized list widget and can be validated against it. i just wanted to know the options without customization.
VenkataKondepati
Honored Contributor
As far as I understand, it is not possible without customization to disable a List widget button based on a URL parameter.
As a workaround, you can use the URL parameter to filter the list data so the button only appears for allowed records.
For true button-level enable/disable logic based on URL parameters, a custom widget or Developer Edition customization would be the reliable option.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
