Unable to refresh or edit layers added to attribute tables
613
6
02-02-2026 08:23 AM
vl-driscolls
I have an Experience Builder with an attribute table added. The user is able to select the 3 dots next to a layer in Map Layers widget and add it to the table. Layers added this way in the attribute table don't seen to be editable within the attribute table, and also there is no refresh button. Is there a way to have the layers added in this way be editable?
OMadarang
Hi vl-driscolls,
What kind of editing would you like to do? I can edit the records from the attribute table by double clicking the cell from the table. If I double click the record I would like to edit for example from Title no. field , it will allow me to change its value.
vl-driscolls
strange, for me columns are locked, even though the layer I have added can be edited outside of the attribute table with the Edit widget. Which version of Enterprise are you using?
OMadarang
Hi vl-driscolls,
It's 12.0.
Have you tried checking the feature layer data setting?
From your feature layer, go to the Data tab, then click Field that you want to edit. You can see the Allow attribute editing  on the right panel.
vl-driscolls
interesting I am on 11.4 and I don't see this option. I am wondering if it is not yet supported for this version of Enterprise or if it has to do with how the layers are hosted
OMadarang
Are you the owner of the layer you're trying to edit?
How To: Enable Editing on a Locked Field in ArcGIS Online Map Viewer (esri.com)
vl-driscolls
yes I am logged in as an administrator
