Unable to add utility services
3325
06-13-2023 12:35 AM
Thomas_Fuhrmann
Hi all,
I'm trying to add a utility service to an Experience Builder app, but when I click on my custom print service or any other service, it gives me the following error:
This utility service is not supported.
I'm using ArcGIS Enterprise 11.1.
DanJiang
Hi @Thomas_Fuhrmann ,
Could you check if your service is a supported service type? And please make sure the printing service URL should include the task level, such as https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%...
DanJiang
Thomas_Fuhrmann
@DanJiang Thank you, it works when I add it via its URL. The problem was just that I wanted to add the item listed in the "Items" tab under "Add utility". Now I see that the problem is that the item listed under the "Items" tab links to the print service and not to the Export Web Map task.
DanJiang
Glad to know the problem is solved!
