Too much white space in Legend widget (Experience Builder)
893
10-07-2025 07:37 AM
HWhitty
I am using the Legend widget in Experience Builder, and there is all this unnecessary white space. (See screenshot below.) How can I trim it down so it looks a little nicer? The scroll bar on the side is not needed either, as there is only white space below the text pictured here. I would love to get rid of the "Custom" as well, if that is possible.
Shen_Zhang
Hi @HWhitty , could you set up a simple app that reproduces this behavior?
Shen Zhang
HWhitty
Hi @Shen_Zhang. Looks like the white space issue has been corrected, maybe as part of the recent update or maybe it was just a fluke. I would still be interested to know how to get rid of the text that says "Custom" though. Let me know if you still need me to set up a public app for that.
Shen_Zhang
I don't think there's a way to remove it from ExB at this point. I looked into it and found that there's no way to remove it from the legend component which ExB leverages. I will see if it can be enhanced from the component side.
Shen Zhang
HWhitty
Thank you @Shen_Zhang . I ended up re-creating the whole app in Portal for ArcGIS (rather than AGOL originally) and for whatever reason, the legend appeared exactly as expected this time, with no "Custom" and no extra white space. Maybe the issue I had was just a fluke. Thank you for looking into it though.
