The top map cannot be dragged when two map widgets are overlapped
586
12-17-2025 04:55 PM
prmhara
Hi everyone,
The Experience Builder application contains two overlapping map widgets as follows.
Map widget A: show a large map. It is the dark map in the screenshot.
Map widget B: show a smaller map on the bottom-right corner of the map A. It is the light map in the screenshot.
I can use mouse wheel to zoom-in and zoom-out the map A, and can also use mouse to drag (move) the map A.
However nothing happen when I try to zoom and drag the map B with the mouse. The map B has a +/- control button and when clicking mouse to + or - the zoom level  (of B) changes accordingly.
Question: how to enable dragging for the map B?
Thank you and best regards.
Ke_Xu
by Esri Regular Contributor
Hi @prmhara,
It is a known issue. Please follow BUG-000175526 Cannot zoom/pan in Map placed within a Map.
Ke
prmhara
Hi @Ke_Xu ,
Thank you very much for your information. I found the bug's url and paste the url here for reference.
https://support.esri.com/en-us/bug/map-widget-configured-as-a-child-component-to-another-m-bug-00017...
Best regards,
