Table Widget Viewing Attachments from a Hosted Feature Layer
1202
10-14-2025 12:56 PM
doronwen
I have a hosted feature layer with "Attachment - Enabled" where users can attach images to point data they collect in the field (using Field Maps). I also have an Experience Builder app where I display the data that is being collected.
In the Experience Builder app, I have a table widget that lists the data that is being collected.
I'd like the users to be able to view the images that are being collected, but I do not see an option to add the attachment field to the table widget under the Sheet Configuration.
Users can view the images on the map's pop-up, yes, but I'm specifically looking to add an option where users can open the image from the Table Widget.
I'm using Portal 11.3
Shen_Zhang
Hello @doronwen, attachment is supported in the Experiencer Builder since Portal 11.5.
Shen Zhang
Shen_Zhang
Shen Zhang
doronwen
Thanks @Shen_Zhang
The Feature Info widget already supports attachments in 11.3, but you are saying the Table widget will support attachments as well in 11.5? Is that correct?
Shen_Zhang
Yes, attachments are supported in the table widget since 11.5.
Shen Zhang
