Table widget not allowing editing for main layer but allows it for the sub-layers. The data sheet configuration is se the same for both layers
280
03-10-2026 07:01 AM
KathyYoung2
I am having an issue with the table widget in one of my experience builder apps since the last update on February. I have two layers and a related table in the widget. They are all configured the same to allow editing on most fields. However the widget is only working correctly for the sub-layer and the related table. The table view for the main table shows all the fields as locked, despite being configured to allow editing.main layer table widget.jpgsub-layer.jpg
Shen_Zhang
Thanks for reporting this — could you please share a sample app (or a minimal reproducible example) that demonstrates the issue? Having access to the app configuration and data setup will help us properly investigate what's happening there. You could also reach out to Esri Support, where they can help you submit a case securely and ensure the necessary details are shared for further investigation.
Shen Zhang
