Table Widget data not downloading when embedded on Experience
930
07-02-2024 04:03 AM
SergioGilDones
The table widget download doesn't work when the dashboard is embedded in an Experience app. It does when you open by itself not embedded.
Do you have any idea how can this be solved?
Thanks!!!
TonghuiMing
Hi @SergioGilDones
When you mentioned the table widget, you're talking about the one in Dashboards or ExB?
There is a support ticket (BUG-000164612) that the Dashboards team is following up on, regarding the embedded app download behaviors. You might want to check if that's the same case.
SergioGilDones
Hi @TonghuiMing ,
I meant the Dashboard table widget. I reported it to Esri and they informed me that they are aware of the issue, and are working on it - BUG-000165078.
Thanks!
