Synchronize time sliders in Experience Builder?
1068
12-08-2023 01:47 PM
KyleBretherton
I am making an app in Experience Builder which has multiple views of the same web map. What I'm hoping to do is to synchronize the time sliders so that all the views are automatically set to the same time, similar to how you can synchronize extents of different views. I haven't been able to figure out any way to do this - is it possible?
TonghuiMing
@KyleBretherton
The Timeline widget inside ExB applies to the data source, thus, you will see the expected changes if all the maps are using the same layer/data source. However, data views are treated as different ones, so you cannot do that in the current environment.
The reason map extent would work, is because it always deals with the map view (same with the original data view).
