Sync map extent between pages in a web experience
633
09-23-2025 08:54 AM
JanetSilb_Spike
Hi, has anyone found a way to sync the map extent between pages within a web experience?  I would like users to navigate to desired bookmarks on the first page, run some analyses, then move to the 2nd page which would then be already set to the same bookmark or extent.  I have only found the option to set a custom extent / initial view for each page separately.
Janet Silbernagel, PhD, ASLA, SITES AP, WBE
Silvernail Studio for Geodesign, LLC
https://www.linkedin.com/in/jsilb/
gis_KIWI4
MVP Regular Contributor
@JanetSilb_Spike  - You can use "action" on the map widget.
I have set up a quick example here.
Page 1 has a map and Page 2 has a different map.
Used the Action on Page 1 Map widget to zoom/pan same extent on Map 2 of Page 2.
Here is a gif in action.
Hope that helps!
