Swipe Widget
1517
07-05-2023 07:36 AM
kbowe94
Is there a way to make it so the swipe widget is permanently on in experience builder? I don't want the on/off popup taking up so much space on the screen I just want the swipe bar between 2 layers to be on when users open the app.
ArekP
In that case, the easiest way would be to create an instant app (media template) and import that app into the window in EB as an embed element.
RyanKammerer
Has there been any work on fixing this? Using the Swipe widget in WAB, it was as simple as turning on the radio button on the bottom left corner of the widget in edit mode. Shouldn't ExB have the same functionality?
Thanks
AlixVezina
I think this is what you are all looking for?
See sample: Swipe example
When you configure Swipe, enable the Default action toggle under General settings.
