Survey123 widget in Experience Builder pull polygon issue
2781
10
07-08-2024 05:54 AM
Daniel_Perkins
When using the Survey123 widget in Experience Builder... I am trying to pull the polygon from a feature layer in the map into the Survey123 form. One of my polygons looks like a donut (water feature in the middle that I don't want to capture).
Each time I select the "correct" looking polygon on the map, it pulls the polygon correctly into the Survey123 form but now includes the center water feature as part of the polygon.
I believe this is just a limit of Survey123 but would be great if someone could confirm. Thanks!
Ruth_JiatengXu
Hi @Daniel_Perkins @JessicaFraver1 ,
This issue has been fixed on the latest version.
Ruth
