Subtype group layer
7515
15
01-08-2024 08:10 AM
BenWalker1
Hello,
I was wondering if anyone had any practical help / guides for using Utility Network data as a subtype group layer in Experience Builder. I really want to take advantage of being able to make fewer calls to the server, but most of the widgets, filter, query, edit etc will not work with Subtype group layers. I thought that perhaps I could configure the widgets to a non-subtype group layer, but it does not really work.
Anyone managed to get this to work? or is it too early to use Subtype group layers right now?
Ben.
BenWalker1
Hi Alix,
Do you have a rough idea of when it might be delivered? I am happy to be a tester once it is available
thanks
Ben
AlixVezina
@BenWalker1 Subtype group layers are not yet supported as a data source in Experience Builder, but are on the roadmap.
BenWalker1
Hi Alix,
thanks
Ben
AlixVezina
Hi @BenWalker1 , we don't have a clear timeline for this right now, but we'll keep you updated!
AlixVezina
Hello - just providing an update that support for SGL in ExB right now is targeted for the release this fall.
JelmerAkkerman
Hi Alix,
can I ask which Enterprise release version you are referring to?
And do you have a more specific date for this release?
Thanks, Jelmer.
AlixVezina
Support is targeted to be added to the ArcGIS Online and Developer editions this fall first, and then would become available in the following Enterprise release, which I believe would be 11.5.
JelmerAkkerman
Thanks for the info Alix, the Developer edition would work for us; do you have a more specific date for the release?
Ke_Xu
by Esri Regular Contributor
Hi all,
Subtype group layer is already supported in Portal 11.4, ArcGIS Online(November 2024) and developer edition 1.15. Analysis and Print widget are not supported now and will be supported later.
Ke
Rob32
by Esri Contributor
Hi @Ke_Xu
Is there an update for the expected timeline for supporting Analysis and Print widgets in Enterprise 11.5?
Cheers
Rob
