Street labels turned on but missing from print widget layout in Experience Builder
4439
12
01-23-2024 03:48 PM
SJ_COV
Hi there.
I have a street layer sitting in a map widget within Experience Builder. I'm trying to use the print widget to make a PDF of the street layer including the labels/street names. When viewing the street layer in Experience Builder's view/edit mode, everything looks good. I can see all of the street labels at various scales. However, when I use the print widget to create a PDF, all of the street labels are missing.
Any insight would be appreciated.
Thanks 🙂
Above is a screenshot of the layer in view mode in Experience Builder. The labels/streets are viewable.
Above is a screenshot of the print widget PDF. The labels are missing, but the street layer is still viewable.
Tags (1)
StevenSGIS
Sorry for the late reply.
Still no solution - I've currently opted to print maps without the labels (for now).
I'll reach out to support and see what they can do.
wstuart4
This has been marked as solved, but it is not. I am also having this issue as of August 2026. Lables are not printing with the print widget.
SJ_COV
Correct, this issue has still not been solved. Maybe @ShengdiZhang could assist since this is an issue exclusive to Experience Builder.
