Static Image Widget
3093
10-31-2022 10:32 AM
Krocha
Im trying to put an image right next to the header text. When i increase the display size (1920x1080) the image moves farther away from the header. How can i place the image where it is static next to the header regardless of screen size?
Tags (1)
DougLogsdon2
The header text will need to be set as pixel as well. Otherwise, it will change position based on the browser width, too.
jcarlson
Set the header's width to a static pixel value, and set the image's side margin to a corresponding pixel value. It sounds like your image's margin is based on a percentage?
- Josh Carlson
Kendall County GIS
Krocha
Yes it was on percentage but changing it didn't help. Exactly how do i set the margin to a corresponding pixel value?
DougLogsdon2
Under the Style tab, Size & Position section, change the unit from % to px:
Krocha
I tried but did not help.
DougLogsdon2
