Sorting a column in the table widget by domain label not code
696
06-16-2025 01:58 AM
KatieQuantrell
Hi, I have a table within experience builder with that contains a few columns that use domain lists. Currently when you select the sort buttons for these columns they sort the records by the domain codes, instead of the domain labels that are what you see in the table.
This doesn't seem very intuitive (as the user obviously can't see the domain codes) and so appears to the user that the sorting on the column just isn't working.
Does anyone know if there is a way to change the settings somewhere for the sort uses the domain labels instead?
Many thanks,
Katie
Ke_Xu
by Esri Regular Contributor
Hi @KatieQuantrell,
Thank you for pointing this out. Currently not.
We will look into this feature further to see if it can be enhanced.
Ke
Ke_Xu
Hi @KatieQuantrell,
Ke
