Single Experience app page with two map layer widgets
8007
12
06-12-2023 06:32 AM
Labels (2)
Webturtles
In Experience Builder I am trying to configure a page to have two map layer widgets, each showing a subset of themed layers with the aim of users just flipping between widgets to turn on/off layers in the main map pane  (easily done in the old WAB).
What is the correct way to do this (assuming there is a way!)?  I have tried having all data in one web map with the aim of sub-setting layers out to each map layer widget, then you get the message related to:
You cannot access the Customize layers setting if multiple Map Layers widgets are connected to the same Map widget.
I also can't seem to take advantage of having two web maps connected to one map widget; so ideally want to link map layer widget 1 to web map 1, map layer widget  2 to web map 2 etc.
What am I missing!?
JohnLucotch2
Good Afternoon,
We have added about 6 Map Layer Widgets with different layers in the Accordion Widget and on initial load, it takes a good 3 minutes to populate before the map becomes usable.  Any tips on better performance?
ChristopherBowering
@TonghuiMing Am I correct in assuming the removal of the limit you mentioned refers to the ArcGIS Online version of Experience Builder?  I am currently working in Enterprise (11.2) Experience Builder and cannot configure/customize layer settings when more than 1 map layer widget is set to interact with the same map.  Is this functionality allowed in 11.3?  If not, when do you expect this to be available in Enterprise EB?  Thanks!
Woosh_AP
What is the status on this? I have started getting this error on Experience Builder (not Developer Edition). I am almost certain that I wasn't getting this error a few months back with the same data.
This Technical Support link suggests it is possible.
